real silent choice with y pipe OR switchable muffler tip
I sold a 96 scarab 29 twin 350 to a friend. Girlfriend says ok but needs to be silent... Since I pay... wich one is the cheapest ? 2nd, do you think muffler tip are efficient enough to shut his girlfriend's mouth and make me sell the boat?
Need your opinion and expertise about that. Thanks! |
Re: real silent choice with y pipe OR switchable muffler tip
the cheapest fix would be to buy her hearing protection....
the silent choice routed through the drive should be quieter.....i agree just buy her earplugs :D
Women really hate when they cant be heard. :D
To install silent choice you will have to pull the motors out to put the y-pipe in. Unless you can do it yourself it's not going to be cheap. |
How about a new gf!
Both options would be good choices to have installed on the girl friend.
Actually, I have the Y-pipe option with staight tips no mufflers. Best of both worlds. Loud when you want it and quite in the channel or at the marina. |
money wise, switchable muffler tips are the less expensive I would guess, right ?
yep
Not to mention 2 motors.
There's just really no comparison between the two. Silent choice through the hub is exactly what it says, silent. It just doesn't work with bigger cams and certain cam overlaps. I use mufflers and they're pretty nice ( CMI ), but nowhere near silent. If I could go through the hub I'd do it in a minute.
Originally Posted by ECeptor
How about a new gf!
:D |
Im confused......you sold the boat and now your gf wants it quieter????
I have the switchable tips and it's every bit as quit as the thru hub. I was very surprised how quit they were and much easier than pulling the engines for the Y pipe.
here is the link from eddie marineSwitchable tips |
Nordic95 |
whats her definition of silent???
You know......you could easily be into $3000 cdn after its all said and done You could throw some inserts in the pipes and tell her thats as good as it gets.....tell her its a performance boat not a Sea Ray Or call Ray at www.doublerperformance.com they're in Barrie Ont.......he could UPS it out your way with no border hassles......he's got all kinds of used muffler set ups around.....doug |
I have some used Y pipes for Bravo with Corsa silent choice electric swith. Complete setup, I liked it but I'm changing my drives to Arnesons and they dont work with surface drives. PM me if your interested
Jud |
cost wise:
ear plugs new gf mufflers silent choice Arange GF depesding on if she has access to your credit cards..... :eek: |
Nordic25, many cam profiles dictate long risers that allow water only at the very end of the riser or even dry pipes with overboard water dumps. This is to eliminate potential reversion during extended idle times. This long riser/dry setup is not possible with silent choice as the diverter is just aft of the short riser and water enters the exhaust right there making it a less than ideal choice for certain cams. I believe an HP500 is about as far as you can go into high performance motors with silent choice. Of that I'm not absolutely certain, but I do know that in the silent choice setups I'm familiar with, there are limitations on the type of engine you can use it with. There may be others, but there are absolutely some limitations. Reversion is a killer.
Kanookstr, I would love to see the switchable tips you are using that are as quiet as through hub. I've used Gaffrig, and CMI's and though they do quiet things a bit, they're no where near as quiet as through hub. My next slip over buddy has a 38' Fountain with twin HP500's and when he's switched through hub he sounds like a Sea Ray cruiser. You can hear the water ripple off his hull sides. My twin 572's with CMI mufflers closed, still sounds like thunder by comparison. It does quiet the noise a good bit, but nothing close to his. What kind of tips do you have that are so quiet ? Also, what motors are you running ? That may have a something to do with your noise reduction.
Check out Rex marine´s PowerSilencer
http://shopping.rexmar.com/Merchant2...-powersilencer they might do trick! /erik |
Throw on a pair of GGB Extreme's
| All times are GMT -5. The time now is 03:25 PM. |
