-   -   head gasket (https://www.offshoreonly.com/forums/general-q/122636-head-gasket.html)
z.zuperboat 02-15-2006 01:40 PM
head gasket
Wat is a good head gasket to use for a supercharge application ?Cometic ? What kind of static compression decrease change will I see going from a 40 thou. gasket to a 90 thou ?
PatriYacht 02-16-2006 08:38 AM
Re: head gasket
Going to .090 will ruin the squish area. From what I've read, detonation will be as bad even though the compression is lower. And it will reduce power. A better solution is to work your comb. chambers for more volume.
