-   -   Scan Tool ? (https://www.offshoreonly.com/forums/general-q/122850-scan-tool.html)
mars 02-18-2006 01:55 PM
Scan Tool ?
What kind of info can I get by having a mechanic to run a full scan and how can I verify what he is telling me is the wright results. Sounds funny of not trusting the mechanic, but this boat that i'm looking to buy is not in my locality and he might know the seller
GOODT 02-18-2006 02:51 PM
Re: Scan Tool ?
depends on the mtr as to what info a scan will give you and as to proof depends on the eqipment hes using
stevesxm 02-18-2006 03:00 PM
Re: Scan Tool ?
some scan tools tell you the number of hours at various rpm... a good feel for how the motor has been treated... they all tell you the total hours on the motor and any diagnostic codes that the motors have generated. not a lot of meaningful info as far as im concerned relative to " purchaseability" . if the boat is expensive and you are paying commercial retail, then you really need to do a leak down, and a bore scope and , depending on your paranoia, an oil analysis. total hours while a meaningful bit of info do not tell you anyting about how it was used or maintained. 200 so some peoples hours are the same as 2000 of other peoples.
Dave M 02-18-2006 04:10 PM
Re: Scan Tool ?
You should get a survey done. It may be required depending on your finance and insurance situation. The surveyor is working for YOU and should have YOUR best interests in mind.
The surveyor should have a scanner and be able to get the relavent info.
Good Luck
GOODT 02-18-2006 06:15 PM
Re: Scan Tool ?
Have to agree with Dave although most surveyers dont have a scanner they can get it done and you will be able to trust the report
mars 02-18-2006 08:12 PM
Re: Scan Tool ?
Good Luck
The boat is in Fond Du Lac Wisconsin and the motor is hp500 2001 (with low hours 100 ???)do you know of a good surveyor in that location.
Thank all for the good replys
