Air Fuel Ratio Gauges
Has Any One Had Any Experience With Air Fuel Ratio Gauges, If So What Kind, And Where From.
Re: Air Fuel Ratio Gauges
I use the Innovative Motorsports LM-1. You must calibrate it before you start, but it is very accurate. It is about $350, but you might find it for less if you shop. I setup some performance marine and automotive engines with it, with great success.
Will That Read All 4 Exhaust Pipes,i Want To Mount The Gauges In The Dash Somewhere.
I mounted the sensor in the collector[drilled and welded in stainless fitting], and it gives me the average per side. It also responds very quickly.
Boatman are you running a wet or dry exhaust?
2 Attachment(s)
I have an Innovate wideband O2 sensor in wet exhausts. I made a spacer plate to go between the manifold and elbow on my Imcos and it works great :D
Only trouble is that AFTER I bought it I found they have a round guage type meter that can be dash mounted :( . |
I have used several O2 gauges in the past. I also take EGT's as well. I have used ones from Summit, as well as big $$ ones. Nordskog has a really nice one. I have used digital, and graph style also. The LED style is nice, probably my first choice after using several different types. They are all only reference, not exact science. I have run them in several different applications, and the main thing is you can't get them wet. Not at all, or the sender will not work. They don't even like moisture. I like to put them in the tail pipe, a couple of inches back to get an average reading from the collector. Remember, with an average o2 reading, you could still be lean or rich in different cyl's and get a good reading. Be careful. Good luck. Bawana |
2 Attachment(s)
Originally Posted by Bawana
Botman,
I have used several O2 gauges in the past. I also take EGT's as well. I have used ones from Summit, as well as big $$ ones. Nordskog has a really nice one. I have used digital, and graph style also. The LED style is nice, probably my first choice after using several different types. They are all only reference, not exact science. I have run them in several different applications, and the main thing is you can't get them wet. Not at all, or the sender will not work. They don't even like moisture. I like to put them in the tail pipe, a couple of inches back to get an average reading from the collector. Remember, with an average o2 reading, you could still be lean or rich in different cyl's and get a good reading. Be careful. Good luck. Bawana Rob |
I Am Running Imco Powerflows, I Do Believe They Are Wet. They Look Like Mopowers.
for egt thermocouples to be effective they have to be ver very close to the port. couple inches away or less.
for o2 sensors to work properly they need to be in a position close to the collector but not so far down stream as to be allowed to " cool" not doing these two things will give you data that is not accurate.... relative for sure... but not accurate. my experience is that o2 sensors not effective for fine jetting...resolution too coarse , but egts work well... key with egts is that the numbers change so fast is not really possible to monitor by " eye" effectively. so i use/ used a data recorder at a high sample rate to get nice clean curves which could then be reviewed in detail and compared to those generated on the dyno. you would be surprised how much power there is to be had by getting the fuel curve correct... and more isn't always better. very easy to over jet carbs or get small float problems that then kill the power by being rich and all that extra fuel ends up in the oil... not a good deal in eiether respect. with this much power its easy to be significantly wrong and not really feel it. |
| All times are GMT -5. The time now is 11:00 AM. |
