-   -   What sparkplus to run in AFR heads (https://www.offshoreonly.com/forums/general-q/123314-what-sparkplus-run-afr-heads.html)
PatriYacht 02-24-2006 10:36 AM
What sparkplugs do you use in AFR heads? I had a tech cross reference the reccomended Chanpion( because they didn't stock the Champions) in a NGK and the plug they gave me was kind'a weird. Thin electrodes, small gap, about .020. The boat ran ok, I'm just curious what other people are running. Thanks, Ian
Thunderstruck 02-25-2006 06:44 AM
Re: What sparkplugs to run in AFR heads
I run NGK's with heat range 8 (NA 502s). I can check the part number when I go to my boat shed this weekend if you need.
Tom
PatriYacht 02-25-2006 08:16 AM
Re: What sparkplus to run in AFR heads
That would be helpful. Thanks.
Wobble 02-25-2006 08:41 AM
When I built my motor I called the NGK tech line, the guy spent about ten minutes with me and was very knowledgeable.
Might be worth a call 1-877-473-6767 prompt #2
PatriYacht 02-25-2006 09:00 AM
Thanks, i'll try that.
axapowell 02-25-2006 09:05 AM
I used the NGK R5671A-7. The -7 is the heat range. -10 is coldest and -1 is the hottest. I think on these heads they only go to 5 or so. I'm running the -7's. N/A 502
Dave
PatriYacht 02-25-2006 10:22 AM
Axa, those sound familiar. Are those the ones with the thin electrodes?
axapowell 02-25-2006 02:30 PM
I'm not sure if they are thinner....not sure what you are comparing them to. That's what I'm using though. My heads are the 305cc CNC'd to 315 cc.
Dave
RLW 02-26-2006 04:41 PM
I am presently running the NGK 5671A-9. This plug does cross reference for use in the Mercury Racing HP900SC motor.
Also, this plug was a recommendation from Dean Nickerson.
I fielded this question to one of our members, Wette Vette. He suggested that I could go to the -8's, with my NA 540, which is equipped with the AFR 305 CNC'd Chamber heads. He didn't think that the -9 would be a problem but could foul out easier rather than the hotter -8 variety.
My engine builder installed the Champion RC9YC4 plugs for the dyno pulls.
I will probably go with the -8's come this season.
KAAMA 02-27-2006 01:40 PM
Those are the one's I am currently using.
axapowell 02-27-2006 06:00 PM
I checked today and I have the -8 installed...sorry
Dave
PatriYacht 06-01-2006 07:57 PM
Finally getting the engines back together. R5671A-9 is what I was running. I think I'll go to 8's to avoid fouling. Thanks for the answers.
axapowell 06-01-2006 10:23 PM
I've got 10 hours on the -8's and they don't seem to be loading up at all. Gonna pull plugs this weekend and see how they are doing anyway.
Dave
Outdrive1 06-02-2006 12:09 AM
I'm running the 8's on mine, the heat range seems to be pretty good, the strap is discolored halfway through it like it's supposed to be. Dart pro 1 heads.
http://www.maxracesoftware.com/spark_plugs.htm
