-   -   small block roller conversion (https://www.offshoreonly.com/forums/general-q/123444-small-block-roller-conversion.html)
Full Force 02-26-2006 09:04 AM
I want to do a roller conversion on my 88 260,what is the cheapest (but safe) way to do this? I want to leave the short block in the boat so i don't want to machine anything.
Will I need new pushrods?
GOODT 02-26-2006 09:06 AM
Re: small block roller conversion
do you have room to pull the cam out????
in most cases the mtr can be out in about 1-2 hrs
Full Force 02-26-2006 09:10 AM
Yes,it will slide just under the seat,I know if I pull it I will do more than I want to,I also don't feel like alighning everything back up to the drive when i put it back in.
GOODT 02-26-2006 09:15 AM
as long as you unbolt the mounts at the base and dont touch the adjustment nothing should change, but to each there own.....
other then that check out crane cams they have some nice roller kits and yes to push rods also
Full Force 02-26-2006 09:25 AM
I can buy a forged roller short block but nobody can tell me how the stock 260 is balanced,I am also trying to find out how my buddys shortblock was done.
His has forged pistons,all balanced,factory roller block,and has close to the cam I want in it already,400.00 takes it but I want to make sure I can bolt it in and go,I am trying to do a low budjet deal here,I plan on a bigger boat in a year or two.
GOODT 02-26-2006 09:29 AM
depending on the year and heads as far as accs go any sb chev will bolt right in
Full Force 02-26-2006 09:38 AM
I know the accessorys will work,I am using vortec heads,My issue is checking balance on the 2 engines.
GOODT 02-26-2006 09:46 AM
you mean on the rotating assy???
rmbuilder 02-26-2006 11:26 AM
245Limited,
Your 1988 factory SBC (provided the engine is a 1988) has a one piece rear seal which means the balancer is neutral and the flywheel is externally balanced. 1988 was the first year the blocks were both one piece rear seal and machined for a roller cam retainer plate and the valley spider to accommodate the dogbone assembly for the lifters. To convert to a roller cam you can simply use a step nose core with the factory lifter arrangement.
To use your friends block you must examine the build sheet and determine if his engine was internally or externally balanced and if the block is set up for the step or flat nose cam core. If his engine is internally balanced you will need a neutral balancer and flywheel and you're good to go. If it is externally balanced it may require a neutral/external balancer and a externally balanced flywheel. In the case you need externally balanced components they must be balanced in conjunction with the weight of your current rotating assembly.
Bob
Full Force 02-26-2006 11:29 AM
Originally Posted by rmbuilder
245Limited,
Bob
I was asked if my block was drilled and tapped before,I did not even think of looking last year when i had the intake off,I should go pull the intake to see.I know his engine was in a 92 camaro from the factory,I am trying to contact the guy that did his work to see about how it was done (balancing)
