crazy gauge?
While turning over engine noticed the tach was going backwards (counterclockwise) then when the engine started, went back to normal. Dont think this has been going on. Have had the engines in and out a couple of times lately. Did I miss something?
Re: crazy gauge?
mine do this also, never been a "problem", just a wierd thing, old race car used to do this too...
Re: crazy gauge?
Re: crazy gauge?
Can't say that I have, just seems like some gremlins may be lurking....
Re: crazy gauge?
It's a voltage thing.....................low voltage typicaly under 10.5 volts makes the gauges act funny. Check all connections but should be ok...........
Re: crazy gauge?
I will check this. As a matter of fact the battery was low at the time and had the charger on "start" when I noticed this. Now battery is charged and will try again. thanx
Re: crazy gauge?
Originally Posted by betitbig
Did you also have you boat worked on by Profile?
LMAO .... :eek: :eek: :eek: |
| All times are GMT -5. The time now is 06:36 PM. |
