New guy – West Michigan noise/Lightning Dry Headers vs. Stellings or CMI
1 Attachment(s)
I’m running a 1990 Baja 250ES that I redid last winter with my dad. Built a 540 up in our pole barn (live between Holland and Grand Haven) from scratch. I can go into details later if anyone’s curious. Also added full hydraulic steering from XS as well as K-planes. We built offshore mounts to improve upon the former setup (2 lags in each stringer). I chose lightning headers with tailpipes – dry to the tips.
Also added a new XZ outdrive with a billet marine top cap. I’m planning to have the drive blueprinted before the season, thanks in advance Dick! I’m currently working out a water leak issue I had last year with my transom assembly – no transom damage thank goodness! That out of the way, I have a few questions: W. Michigan noise issues: Have any of you had issues with the Grand Haven/Holland area for noise using dry headers? I’m periodically using inserted glass packs to quiet things a bit, just seems like I’m a bit loud even yet. Any issues with police/DNR? Stellings/CMI question: I have an internal water exit through holes in the last inch of the tailpipes. This allows me to use shotguns/external rubber flappers. For those of you using dry stellings or cmi’s – where does the water typically dump? Pictures would help immensely. With my setup, the water comes out with a lot of force with the help of the exhaust. When I use a secondary rubber flapper on the outside, water or water vapor appears to be reverting just due to the flapper being slightly in the way. Just a little bit a condensate in the header, but I want to eliminate all issues. I just want to say thanks to everyone for the kind of quality question/answer information there is on OSO! I don’t know many of you, but I’m a regular in Grand Haven – would love to meet fellow OSO’ers. I’m not very forum savvy, seems like last year I was just learning from what’s already online, never posted anything. I wanted to get my name out there in case I see anyone in the West Michigan Area this spring/summer, sick of being a stranger! Thanks! Tibbstoy2/Jeff |
Re: New guy – West Michigan noise/Lightning Dry Headers vs. Stellings or CMI
You need to be talking with Waterfoul. He's in that area and was/is running the same boat as you. PM me and I'll see if I can get you his number.
I am from Grand Haven...they were starting to really crack down there when I moved about a year ago.
1 Attachment(s)
Alot of my friends have been given tickets and warnings for loud exhaust. Mine is louder but I have the Drew Marine shotguns. My exhaust is dry to the end of the my pipes and dumps water at my shotguns. I usually idle with one engine through the channel w/ shotguns shut, if they open I have been stopped and showed the sherrif that my shotgun had opened. I put it back down and he had no problem. I think It was more that I showed the effort to silence my exhaust. But in 3 years and only stopped once I don't think that is to bad.
One of my shotguns fell off. |
I have stainless marine dry with no flaps on the end of the pipes and have never had an issue from New Bufallo to South Haven. I was told by a sheriff that if you are not reving or throwing a wake in the harbors, you wont be bothered. If the boat doesnt sell by mid June, I will be in Grand Haven to watch SMOKE. Maybe they are different up there.
Rebel4845, that is also what I have Stainless Dry
1 Attachment(s)
Thanks for the input.
Rookie - When I installed shotguns, the water would hit the outer valve, most would go through the holes, but some water or water vapor anyway would get sucked back up the pipe. What size engines are you using, and what type of cams? I'm running a custom grind Comp Cams hydraulic roller cam - lobe separation of 112* with .633 intake/.648 exhaust lift. Not too radical, but will have some overlap. That's why I went with an exhaust system that is dry to the tip. One of the reasons I'm inquiring on this thread is that I'm thinking about plugging the water holes inside the tips and adding a bung on the top of the tip, forcing the water to leave without touching the vortex in the exhaust stream. Problem is, by doing that, I will not be able to run shotguns, or external flappers (I do have an internal at least). That would put me at completely dry exhaust - with no way to get quieter than the glass packs I currently use. The last thing I want to do is mess with reversion though!!!! :eek: Here's a picture of what's going in inside... |
I only have some 468's, cam is just a little more than the stock 425-525sc cam. I also have 2 more feet of exhaust pipe cause of trannies. I also think I had a little problem when I had the springs to tight in my shotguns.
One fear I have of having shotguns is popping one off - almost out to have them on teathers :D . The tight spring wouldn't help that situation due to high pressure.
When I ran shotguns - only in the driveway - I shut the motor down, had a look up the tailpipe with a flashlight - condensation through the collector on the header. Glad I never let the engine get warm. My only option seems to be to run dry, with only an internal flapper, before the water mixes in at the tip. If anything else gets in the way - even the flapper, reversion seems to happen. Anyone running big cams with shotguns and similar exhaust? Thanks! |
I have a similar set-up. My tailpipes had 8 holes at the tip for the water to exit. I had all but 2 welded up and have the water going to a thru transom dump. Enough water goes out the tailpipe to cool the mufflers but no reversion problems. I'm running 540's, AFR335 heads, 236,240 duration @ .050, .630 lift. Stainless Marine made the tailpipes.
Patriyacht, sounds like a very similar setup... I'm running modified AFR 325's, sweet heads. Does your primary water dump occur at the beginning of the tailpipe - I've seen ones that dump near the end as well, around 3/4"-1" diameter coming off the tailpipe. I'm assuming the dumps comes off the top of the pipe to avoid hotspots??
Also, with less water, are you running shotguns, what kind of muffler? How does that work with less water? seeing that the water does a lot of the quieting in a shotgun. Thanks, Tibbstoy2/Jeff |
Not sure what you mean by primary water dump. The water goes from the manifold to the tailpipe via a 1" hose to the top. Water travels to the tip and exits. A new bung was added just inside the transom on the upper side to make sure the tailpipe stays full of water. I'd take a picture of the inside where the inner and outer pipes are welded but the boat is in storage. I'm using Gaffrig mufflers with the air operated flap that closes and forces the exhaust out to the sides. They are very restrictive and should not be used above about 2500 rpm.
