Ujoint drive shaft angle
Currently running a 36 Nor-tech w/525's and XR's. thinking about upgrading engines to 650 or so hp. the boxes and drives are set inboard of the engines and there is a pretty extreme angle on the u-joint drive shaft form the engine to outdrive. if i upgrade power i think this may become a weak point. How extensive of a project would it be to realign my boxes and drives and move them outboard. I could also raise the x-dim (already getting a lot of bow lift so this would be good).
or could i realign my engine, move up and inward and get a custom exhaust made. or upgrade the ujoints? any suggestions welcome. thanks -Rick |
Re: Ujoint drive shaft angle
your best bet would be to talk to nor tech and ask them Im sure theyve tried all poss combinations
How much of a difference between the engine centerline and the drive. How long is the driveshaft from the motor to the ext box . Do you have a picture you can post.
My OL is set up with the motors at 34" and the drives at 29" .Drive shafts are approx. 18inch long . . My are motors 557" with 1071's and #5's on boxes. No problem with u-joints . Tom |
The accurate measurement method is to use a digital angle finder. My research into u-joints in a high performance/high RPM application determined the optional angle is .5 to a max of 2 degrees. I would not think the boat manufacturer would be a great source for accurate info. Sometimes the focus is to get the X-dimension right and then to just get the rest of the drive line and engines to fit into the boat with the hatches closed.
I rigged a 35" Motion cat a few years ago with a set of 1000's we did and 6's. I moved the engines as far forward as I could and still had the driveshaft on a pretty good angle. I talked to the driveshaft shop that built the drive lines and they said we should replace the u-joints every year just as a precaution. I never have heard of the boat having any issues and I know it has been used quite a bit.
just another .02. :D John S. |
My OL is set up with the motors at 34" and the drives at 29" .Drive shafts are approx. 18inch long . . My are motors 557" with 1071's and #5's on boxes. No problem with u-joints . Tom What type of shafts/u-joints are you all using? I had a u-joint blow on my rover on the highway and take out my trans, something i do not want to repeat on my boat. thanks for the info, keep it coming. -Rick |
To keep vibration to a minimum and provide decent service, no more than 3 degrees. That's how we set up the military boats.
Kurt |
Originally Posted by LostinBoston
my quick rough calculations puts you at about an 8 degree shaft angle. I'll be able to visually inspect mine tomorrow night and get accurate #'s but i estimate mine to be about 12.
| All times are GMT -5. The time now is 09:50 PM. |
