-   -   Has anyone used these Summit heads? (https://www.offshoreonly.com/forums/general-q/123910-has-anyone-used-these-summit-heads.html)
1BIGJIM 03-03-2006 02:20 PM
I would really like to see the flow numbers :rolleyes:
Any idea who made the heads?
http://store.summitracing.com/defaul...h.asp&x=18&y=8
duunoit 03-04-2006 08:14 AM
Re: Has anyone used these Summit heads?
That would be interesting to know....
PatriYacht 03-04-2006 10:00 AM
They look like Dart Iron Eagles. Good choice for running in salt water.
ratman 03-04-2006 10:25 AM
call summit and ask, i think they own trick flow which makes a lot of the summit branded speed eqiupment
ratman 03-04-2006 10:27 AM
id go with alum, all the good alum heads are coated to prevent corrosion, and you're less likely to detonate an alum head eng.
1BIGJIM 03-04-2006 11:39 AM
I don't run in salt so corrosion is not a problem. Just the exact runner size and valves I am looking for. Only if they had the flow numbers. I know nothing is free, just wish they had more info, or someone who has had experience with them.
Raylar 03-04-2006 12:54 PM
These iron heads seem to have pretty good specs. and the 308cc intake runner will be good for midrange torque and a BBC motor up to 540 inches with mild compression of lets say 9.0 to one. I think if your going to be running fresh water, I would spend a bit more and step up to a decent set of aluminum heads with similar specs that will let you run 10.0 to 1 with the same fuel octane. that extra point of compression is good for at least 25 more HP and a little more torque, not to forget you just thre another 100 lbs off the boat." Eventually they stopped using swords made of iron and stepped up to steel"!
Ray @ Raylar
Griff 03-04-2006 01:40 PM
I would want to know who made the valve springs and what valves are in it. I really doubt the valves are made of a material suitable for extended marine use.
Big Block Billy 03-04-2006 01:45 PM
Yes, I used the 308 CC on my 540.
Using 345cc on a pair of 588's for a friend. Any bigger that 540 use 345cc. Dart heads are awesome ! They are really the way to go. Anyone need stock chevy heads ? I'd like to flush out my tremendous inventory. BBB
Big Block Billy 03-04-2006 01:47 PM
Also using all Rev brand parts. Inconnel 11/32 valves, Titanium retainers etc... BBB
cig1988 03-05-2006 03:28 AM
What's the casting #'s on the heads?
ratman 03-05-2006 12:52 PM
sell the valves that com ein the heads on ebay and by severe duty int and inconel ex, and tit retainers. thats what i did, the difference i paid for the ss valves less the ebay sales was minimal.
