-   -   Can a 572ci make 850hp na? under 6000rpm (https://www.offshoreonly.com/forums/general-q/123952-can-572ci-make-850hp-na-under-6000rpm.html)
soinc 03-04-2006 12:30 AM
guru's of oso I need your help ...
can this be done and have the motors live?
making upper 700's now..you know how it is their is never enough under the hatch ;)
Shawn
woody1 03-04-2006 01:24 AM
Re: Can a 572ci make 850hp na? under 6000rpm
Shawn
Im not sure of the chevy's efficiency but we can make that with the 557 inch Fords, fairly easily, 6200rpm. It's a little over 1.5 hp per inch :D
ratman 03-04-2006 01:43 AM
steve schmidt has a 925 pump gas na motor i think is a 572 short block. 800+ ft lbs of tq, for 25k ea, sweet looking mills
PatriYacht 03-04-2006 09:27 AM
Doubt it. It would take more r's and unboatlike things like very high compression. Put 4-5 lbs of boost on it and make more hp with less wear and tear.
Brad Zastrow 03-04-2006 09:53 AM
I do not think you will get to 850 on 93 octane. Race gas you can. It will take too much compression. I have been told about 750 is it with 572 CI N/A without spending big bucks for the exotic stuff. Horsepower costs money. The saying goes: "Speed cost money, how much do you want to spend?"
pullmytrigger 03-04-2006 10:11 AM
whats a Ford???? :D
ratman 03-04-2006 10:34 AM
wrong! TWIN 585 MARINE SSCE POWER, 980 HORSEPOWER & 825 FT.LBS. OF TORQUE,
• Runs on Regular Gasoline
• 10" of Manifold Vacuum
• Great Idle
• Terrific Throttle Response
• Built To Run 100's of Hours Before Maintance 26,950ea
heres the link to thier site
ratman 03-04-2006 10:37 AM
its a 585 ci eng, probably 4.625 stroke vs 4.50 for a 572. if i had know about these bad azz na engines i would probably have a pair of these in my cig now! beatiful engines, and these guys make 1000+ hp with single centrifical blower with single 850 cfm carb on a 572!!!
gg10 03-04-2006 10:39 AM
last year I made 820hp @ 5700 with this combo on pump gas. 4.375 stroke, 4.6 bore, 582", static cr 10.5, dart heads, crane hyd roller, eldelbrock victor with a BLP carb. in the boat you need a very good set of headers to see the hp, run cold h2o temps and keep a good tune, ran 130 hrs last year. This year I am rasing the static to 11 to 1 and sent the intake to keith wilson for blue printing. I am hoping for 850 to 875hp. gg
ratman 03-04-2006 10:40 AM
btw im sure you could get them to build a little smaller eng like a 572 and make 850 hp, but i would stay with a proven combo like the 585 set up, good luck. let us know if you get a pair! peace out, rm
