Fuel pump specs?
Does anyone have the information of fuel pump capacity gallons/hr and pressure/flow rate of 1996 7.4MPI 310hp with returnless fuel system, and injectors size? I have a project engine that is using aftermarket ECM, but if possible trying to use original parts as much as I can. I need also a part # of connector for injector wiring harness if available separately.
thank you in advance, Mike |
Re: Fuel pump specs?
TT Anybody???
Can't find the info you wanted on the fuel pump, merc doesn't give out that stuff just what pressure its supposed to have. as far as the harness connector, they show a breakdown of the whole thing then list one part number for the injector harness. So here that is 84-805232A4, this is just or the injection. Ed
| All times are GMT -5. The time now is 07:42 AM. |
