-   -   #6 questions (https://www.offshoreonly.com/forums/general-q/124296-6-questions.html)
OkieTunnel 03-07-2006 10:46 PM
#6 questions
What is the difference between dry sump and wet sump #6's? What is the difference between the old style #6 and the new swept skeg? I am considering a boat with wet sump #6's and would like to know the differences.
HotPursuit 03-07-2006 11:11 PM
Re: #6 questions
Dry sumps run little or no oil .Wet sumps are filled lower and upper.Dry sumps depending on HP and hull design will increase speed 3-6 mph.Less gear drag with no oil.
New swept back skeg design should give better high speed handling.Different shape and style.
OkieTunnel 03-08-2006 07:09 AM
Re: #6 questions
Thanks for the info.
Nykamp 03-08-2006 07:47 AM
Re: #6 questions
The real early K drives had the tie bar mounted on the back of the drives and the newer ones have the tie bar mount on the top of the case. If it is the real early #6 K drives make sure it has had the work done to handle the updated gear sets.
Spine Tingler 03-08-2006 08:22 AM
Re: #6 questions
You can't afford a new boat :D
shark42 03-08-2006 02:26 PM
Re: #6 questions
Damn Scott, OUCH!! :eek: :D
OkieTunnel 03-08-2006 02:49 PM
Re: #6 questions
Shart 42??? Oh, shark 42 :D :D :D
I can't afford well adjusted's new boat thats for sure.
44MTI 03-08-2006 03:21 PM
Re: #6 questions
He only thinks he's getting a new boat. :eek: :drink:
