-   -   Need some help with 502 Problem (https://www.offshoreonly.com/forums/general-q/124614-need-some-help-502-problem.html)
briana 03-11-2006 05:06 PM
Recently, I performed an arizona speed upgrade on my 1998 502 efi motors, new dart heads, cam, rockers, msd ignition computer remapping,cmi exhaust etc. in theory they should be running close to 500hp at the prop.
here is the problem that I need help with:
my port motor backfires at idle but the timing is set perfect and all clearly obvious reasons for the backfiring have been checked. the motor runs 400 rpm less that starboard at wot and the performance of the boat is 4 mph less than stock before i performed the upgrade.
the boat is proped to run 5200 rpm wot .
oh by the way the boat is a 1998 35 fountain
any advise at this point would be great.
liquid asset 03-11-2006 07:31 PM
Re: Need some help with 502 Problem
Im dealing with a similar prob, my fuel pressure regulator was coroded and was showing 90 psi fuel pressure, after repair back to 41,
mr mercruiser 03-11-2006 07:34 PM
maybe you have a bad injector-did you do a cylinder drop test?-
briana 03-11-2006 11:31 PM
wouldnt the bad injector come up as a code on the ddt
stevesxm 03-12-2006 03:49 AM
no... as long as the pulse is present, there will be no code. you might want to look at something REALLY simple like the firing order... it is really easy to get the wires mixed up on the cap and and will give you that idle backfire yet SEEM to run sort of ok...
did these things run on the dyno when complete ?
Griff 03-12-2006 03:56 AM
Have you rechecked the valve lash?????
I would do a leak down to rule out a valve that is sticking open.
briana 03-12-2006 06:16 AM
There was no dyno time. I will perform the leak down test and see about a valve. as far as spark plug wires go they are all in the right spot, double and triple checked.
one other idea is, az speed did the computers, could one of the computers not have been flashed correctly?
Vinny P 03-12-2006 06:33 AM
Try to swap ecu's between your 2 engines. If the problem follows the ecu, you got the problem found. If not, get into checking the motor.
briana 03-12-2006 06:38 AM
the reason why i post this question is this:
prior to the motor upgrade the motors were stock 502 mpi, the boat ran 72mph at wot with bad compression ot of the port motor spinning 26 hydromotives non labbed @5100 rpm. obviously we all look for more speed so an upgrade was performed instead of a valve job.
here is where my performance numbers are at now after the 20k upgrade
5000 rpm starboard
4600 rpm post this is the backfiring motor
68mph wot spinning the same props before the upgrade
Is the port motor causing me to lose this much speed, i was thinking i was going to gain 10 mph with the upgrade not lose 4.
az speed told me the motors should now be producing 520 at the crank and about 500 at the prop. comparing this to 35 lightnings model year 96-99 running 500 hp they perform 80 to 82mph
some thing is wrong here?
Payton 03-12-2006 07:52 AM
Sounds about how mine ran with a rounded cam lobe.
mr mercruiser 03-12-2006 08:01 AM
an injector wouldnt present a code on any scan tool
liquid asset 03-12-2006 08:38 AM
I had the injector problem too, threw no codes and at 85 hours
briana 03-12-2006 09:43 AM
I will swap computers on monday, if thats not it i will check everything else mentioned above and post findings later.
thanks alot guys
stevesxm 03-12-2006 10:01 AM
well... first... 10 more mph is going to require about an additional 200 - 225 hp PER engine at that speed....
second... whoever suggested swapping the ecus is spot on...that gives you a quick answer right off... and the same goes for the rest of the sensor array
it sounds to me like a warrantee issue for arizona speed. also... if i read your post correctly you said you were looking for 500 hp... didn't those motors make 425 to start ? soo all this work for 75 hp / side ? sounds like a not great deal to me...
powerquest 380 03-12-2006 10:39 AM
how much faster do you thnk that boat will be with an additonal 100 HP per side?
Dave_N 03-12-2006 11:19 AM
I agree that a failed injector(s) will not set a trouble code, but did you check for trouble codes? I also agree that swapping the ECM's would be a good place to start.
While you are troubleshooting, I would disconnect the MSD boxs, recheck the timing and run without them until you find the problem. It's all about eliminating possible causes.
Dave
stevesxm 03-12-2006 03:03 PM
we had this discussion the other day and someone found a pretty good calculator on a site somewhere. i use the math.
HP = drag x V cubed ( in ft per sec)
you say you had 72 mph w/ stock 502's so about 850 hp
so back into your drag number... 850/ 1177583 = .00072
so
hp = .00072 x 1715932 ( 82 mph cubed in fps) = 1235 hp or another 385 hp total...
am sure the online calculator will give you a similar number
1050 hp should give you about 5 mph give or take
briana 03-13-2006 10:43 AM
during some troubleshooting, a map sensor code came up on the ddt, i will be replacing the sensor, can this be the total problem?
briana 03-13-2006 10:45 AM
the injectors are all working correctly 46psi
stevesxm 03-13-2006 11:46 AM
just exchange maps sensors between motors. also... don't understand your comment about "injectors working 46 psi " pressure and actual electrical injector function unrelated.
briana 03-13-2006 08:52 PM
talking about fuel pressure
Darkspoilerzx 03-14-2006 08:11 AM
Is the backfire steady under a load or does it just do it at idle, it sounds to me like a lobe off the cam, or plug wires 5and 7 are switched around. How were the cams broken in. Ed
briana 03-14-2006 09:20 AM
just at idle, the backfire goes away under load but the motor lags bigtime underload throughout the whole power curve and is apprx 500 rpm off at wot. the cams home less than 2 hours on them and the backfire started upon first start, this should rule out a rounded lobe.
Darkspoilerzx 03-14-2006 10:21 AM
Then I am back to the wires being wrong or maybe a mis adjusted valve....I have seen a lobe round off on a cam in less than twenty minutes of running time with to much spring pressure and not enough assembly lube or improper assembly.....Ed
briana 03-14-2006 12:41 PM
yes, i agree. but i saw the cams go in a they were lubed well. valves were torked to specs I watched each one done.
wires are all in the right locations. i really do not want to pull the motor again. what is the best test to see about an mis adjusted valve, my engine compartment is perfect you can eat off the floor dont want too much mess.
Griff 03-14-2006 01:56 PM
If it started upon initial start up, I would think it is a valve not fully closing or leaking---rocker arms adjusted too tight maybe.
Griff 03-14-2006 02:03 PM
What do you mean by "torqued to specs"??????
They should not be torqued unless it is a stock cam with the stock rockers and bolts.
Everything you describe sounds like the valves are too tight.
blue thunder 03-14-2006 06:54 PM
I would have thought this a roller cam, but if you are concerned about a lobe going away, chisel open the oil filter and check for metal.
Is it popping out the exhaust or intake side?
BT :cool:
briana 03-14-2006 08:37 PM
it is a crane cam and crane roller rockers dart heads
Darkspoilerzx 03-16-2006 01:13 PM
A leak-down test is probably the leest messy, and would tell you exactly which cylinder and which valve or valves. pulling the valve covers and checking the adjustments is messy and time consumming but equally as effective. Griff is right valves donot get torqued they get adjusted to zero lash and then somewhere between 1/4 and 1 turn down to center the lifter piston in its bore. Ed
Rebel_Heart 03-16-2006 06:44 PM
I had the exact same work done by ASM several years ago and only picked up 4 mph. Didn't think this was too good, so I'm heading in a different direction.
Back4More 03-16-2006 07:55 PM
If you still don't find it....MSD has a good troubleshooting section on their Ignition systems.
mats 03-17-2006 05:35 AM
Have you checked the fuel pressure all the way up to WOT? .
briana 03-17-2006 05:54 AM
after much troubleshooting the problem was a combination of three things, a map sensor was bad, a pcv valve was stuck open, and i reinstalled all the spark wires and the problem went away. motors are running great but
now brings my next question, iam very unhappy with the performance after the upgrade this is why.
before the upgrade with 1998 tired motors one motor had 90 compression on 2 cylinders the boat ran 72.1 gps full fuel,2 people, spinning 26 hydromotives @5000 rpm wot.
the upgrade was asm, new upgraded crane cam, dart heads, msd ignition, roller rockers, cmi exhaust and a computer reflashing. cost of parts was approx 18,000.00.
heres what the performance is now(it sucks)
between 1/2 and 3/4 fuel,2 people, 26 hydromotives compression is back to 150+ on all cylinders. boat ran 74.4 gps @5000 rpm
water and wind were the same before and after.
the only thing i did not do was change the intake to get more air into the motor. do you guys think this is hindering the new heads and cam from working properly ie creating more hp?
JasonSmith 03-17-2006 10:14 AM
I don't think the intake is what is causing the HP loss. Tyler Crocket does a simmilar upgrade to the factory MPI motors. He gets 100HP more a side by the same means you have went with, only with different components.
