-   -   Help with Bravo Gimibal removal (https://www.offshoreonly.com/forums/general-q/124691-help-bravo-gimibal-removal.html)
klaw 03-12-2006 05:54 PM
Well its been a fun wekend I had to make a few tools but I have the gimbal completely loose upper pin is out (that was a *****) lower pimn is out shift cable is out
Only thing holding gimbal on is water hose I see that it goes through transom and enters back of gimbal but no hose clamps on either end how does this hose come off ?
GOODT 03-12-2006 06:18 PM
Re: Help with Bravo Gimibal removal
1 Attachment(s)
im guessing that its a bravo
here you go, rather then explain this is easier then typing
klaw 03-12-2006 06:34 PM
thanks my clymer maual did not have that
by looking at it I was assuming it was sometning like that do to looking at the insert it has 4 indentations in it will make a special socket att work tommorrow Need to get that lathe and mill for the house to be able to make these tools at home
GOODT 03-12-2006 06:40 PM
:drink: :drink: :drink: the tool is only like 5 bucks from merc
klaw 03-12-2006 06:55 PM
yes I have found the biggest mistake is not sizing the job up properly before starting it of if a local merc guy has one I will pick it up
also need to have the Merc manuals they are prob a little better then the clymer which did not have this disassembly procedure in it.need to finish getting them off tommorow to send out for rebuild
drives are already at my merc guy for going through
only have about a month for splashing so got to start to hurry
Elite Marine 03-14-2006 08:42 PM
Buy some HD Gibles and some new XR Drives Klaw. While you're at it through in a couple of 600's and you'll be in great shape for summer!!
See you soon!
Kirk
GOODT 03-14-2006 08:54 PM
See you soon!
Kirk
lmao wish I or for that matter my customers had your DEEP pockets
klaw 03-14-2006 09:28 PM
35 hp a side would not help that much but the xrs sure would be nice
See you soon!
Kirk
