-   -   Safe rpms (https://www.offshoreonly.com/forums/general-q/124722-safe-rpms.html)
docmanrich37 03-13-2006 06:10 AM
Safe rpms
What is a sfe rpms for 525 efi with whipples?Dustin says to turn them 6000 and when summer gets here it will still turn about 5700-5800.Is this to high for stock 525's.Old rev limiter was set a 5450 and dustin says he's test that the 525 was still building power at 6000- and set the rev at 6200.I think its to high and want the rev set at 5800.Am i wrong ?
excursion 03-13-2006 06:26 AM
Re: Safe rpms
I think that you should have them set at 3500 rpm, that should be perfect!!!! I should be able to run right with you at that. Motors will live all summer........... :p :p :evilb: :drink:
docmanrich37 03-13-2006 06:31 AM
Re: Safe rpms
That sounds good but i think i was running about 92 at 3500. :D Hampton is going to be fun this year. hang on girls and no James you can't help them hang on.:D :D :D
Darkspoilerzx 03-16-2006 01:27 PM
Re: Safe rpms
Stock prop range is 4600-5200 if you didn't change the valve train and do a bunch of work in the bottom end I would stay down under 6,000 It may mean the difference between floating at the dock and boating all summer.
Ed
Darkspoilerzx 03-16-2006 01:30 PM
Re: Safe rpms
After re-reading your post, are you using the rev-limiters to control wide open throttle rpm? Or does he want you to prop it to turn 6,000 rpm's ? Ed
gsmith9898 03-16-2006 01:50 PM
Re: Safe rpms
better to be safe than sorry. take the whipples off and send them to me. :D
docmanrich37 03-16-2006 02:57 PM
Re: Safe rpms
Prop it to turn 6000 plus it still was building power at 6200.
docmanrich37 03-16-2006 02:59 PM
Re: Safe rpms
G you have to come off the $$$ cause have you ever seen a hearsh pulling a u-haul. :D :D
