Engine Builders - Charlotte NC
Looking for someone to finish a 496. I have all the parts (heads, CAM, ect), just need it assembled.
What is the turn around time?? John |
Re: Engine Builders - Charlotte NC
I'm surprised by the lack of replies!
I used to deal with CRD when I was runnin' NASCAR craftsman trucks, he also did some SCCA stuff for a friend of mine. I don't know how busy he is or if he even does marine but you can call him 704-794-1955 Bob |
I took mine to Dell Marine in Jacksonville, because of the lack of engine builders in the area.
Give Kevin a call 904-730-9968. He is completely rebuilding my port 500 efi. |
Thanks Steel.. I just called him.. Sounds like his prices are reasonable and his turn around time is quick.
I also am surprised at the lack of responses. I figured someone out there would be willing to take the $$ and run.. |
There are literally hundreds of engine builders in the Charlotte area, but most are so busy, it normally takes about a month or two just to get on their schedule. There are to many to list, and a lot of boaters here often build there own with a little help of a friend or 2.
Check with Fred @ Trick Marine. He can get you in touch with Mark from MER in SC. Great guy and even better builder!!!
| All times are GMT -5. The time now is 08:19 AM. |
