Honda PWC oil change ??
Trying to get the Honda ready for the summer for the kids.Anyone have any knowledge on getting the oil out of the engine. Its an F12X Turbo 2002 model. I know you have to suck it out of there, I'm just not sure where to start. I have a pump system I use for my boat, just wondering if that would work.
Also changing the plugs. They want close to 300 bucks at the Honda place and thats just CRAZY!! :mad: Any help would be greatly appreciated! Thanks, Shawn |
Re: Honda PWC oil change ??
at the back of the pwc between the battery and the engine,sort of under the exhaust there is a black plug that is facing up,unscrew it and inster the suction hose all the way in,the plastic hard type hoses work the best,and pump away!youll pull about 4 quarts out!once the filter is changed,add 2.5 quarts of oil and run it for 30seconds,water not needed,shut it off and check the oil level!then keep adding unitl you reach the right level(every time you add oil,run engine for 30sec because the oil is stored in a seperate tank) this will bring the oil level were you want it!
Bro!
Thanks for the info! Its a great help and will save me some dough!! God ,,,I luv this board!! :evilb: :D Thanks again, Shawn :D |
If any more questions,call me at performance motorsports,949-493-5004 ext 126!We sell those suckers!Im the gm,if i cant help,ill get my service dept involved!
I have an old electric fuel pump with some hoses and some gator clips for the battery I use to suck the oil out with. If this doesnt work I will give ya shout.
Thanks again! :D Shawn |
| All times are GMT -5. The time now is 08:15 AM. |
