-   -   pros&cons of intercoolers (https://www.offshoreonly.com/forums/general-q/126100-pros-cons-intercoolers.html)
selfmade 03-29-2006 03:20 AM
I want to install the 125hp superchiller intercooler kit on my 575sc i want to know the pros and cons of this any input would help out alot thanks guys
Dixie Doug 03-29-2006 10:36 AM
Re: pros&cons of intercoolers
Pro's Maybe 125hp gain(weather ect)
Con's $2500.00-$3000.00
Steve Zuckerman 03-29-2006 02:40 PM
1 Attachment(s)
Self,
Running the Whipple intercooler on a 575. Advantages are you can run a much smaller pulley (4" stock/I'm using a 3" for 7PSI boost intercooled) on your blower. You'll need to get your ECU reprogrammed too.
Lots more HP, much better performance in hot weather.
Downside, not much. Just realize you'll need 4" of addition vertical clearance with the superchiller (I used the whipple, it's 1 5/8"), you'll have to run some additional plumbing, and I do recommend a sea strainer for the intercooler. If you crank up the boost, I would also change head gaskets to FelPros or Cometics. The factory gaskets aren't much.
Here's picture of the installation.
Steve
selfmade 03-30-2006 02:57 AM
thanks steve
Steve Zuckerman 03-30-2006 08:49 PM
thanks steve
self
Anytime. Let us know how yours turns out. What boat are doing this on?
Steve
