-   -   imco extreme sc ? (https://www.offshoreonly.com/forums/general-q/126292-imco-extreme-sc.html)
Strip Poker 388 04-04-2006 11:34 PM
Re: imco extreme sc ?
Originally Posted by Rebel_Heart
Does it make much of a difference if the engine is NA or supercharged? I was told that bravo style drives have a longer life with a NA engine. Does the torque hit earlier on most supercharged engines? Asking because of my new 700 hp NA engines.
Depends.NJSonic has some NA motors that have high 800TQ and was breaking the New MaxMachine works.
Again some people break the drives with stock power .Some people are tuff on there shet.
The TQ on the supercharged motors are usually higher than a NA. You can get into boost just getting on plane if you want to load the engine that hard , thats tuff on drives. :eek: Some supercharged come on Early and some late.
Like on my Whipple supercharger with it turned UP :eek: it had 10.25 lbs of boost at 3600RPM and had 925.6ft-lb at the 3600RPM. That will break a drive :rolleyes:
Rob :drink:
Strip Poker 388 04-04-2006 11:37 PM
Originally Posted by tomcei
Next year I plan to up grade power to approx 750+
currently at 600+ and have an xz drive. I ran across an imco sc for $5500.00 w/ 20 hrs in good shape. Question... Should I pick this up?
I need a seasoned vetrans advice.
What kind of boat and weight?
