-   -   Oil Temperature on a 500EFI (https://www.offshoreonly.com/forums/general-q/126432-oil-temperature-500efi.html)
Mikey Likes It 04-01-2006 10:07 PM
What should the oil temperature be around on a 500EFI? Also should the temp fluctuate at all?
Mikey Likes It 04-03-2006 10:06 AM
Re: Oil Temperature on a 500EFI
FYI- I called Mercury today to find out.
Oil temp - 180- 240 if you hit 280 cruising you should get concerned if you hit 280 running WOT don't worry to much.
Water Temp 160 -170.
