-   -   Who has the best shorties? (https://www.offshoreonly.com/forums/general-q/126703-who-has-best-shorties.html)
SCRAPMAN1 04-06-2006 05:07 PM
Re: Who has the best shorties?
One Thing To Note Is The Imco Skeg Is Approx 2" Shorter Than The Merc Units. Depending On Set Up This May Cause Handling Problems. Also- It Is True That These Units Have Had Water Pressure Issues On Some Applications- I Had Both Issues On A Stepped Hull 42 Fountain. Hope This Helps.
SCRAPMAN1 04-06-2006 05:11 PM
Oh Yeah I Almost Forgot- I Saw No Speed Increase On Back To Back Tests Between The Imco Units And Sportmaster Mercs. On The Flip Side Some People Claim They Have Seen 2 Mph And Swear By Them.
Rebel_Heart 04-06-2006 09:01 PM
There would most certainly be a speed increase using either the Imco or Bravo Shop lowers vs. the standard Bravo drive, right? I would think that the combination of the shorter drives along with the bullet shaped cone would add to the speed at higher speed applications.
Strip Poker 388 04-07-2006 08:41 AM
Originally Posted by Ran-Dom 32
I went with the bravo shop lowers, to avoid water pressure problems & try something different, I had tried sportmaster -2 lowers prior to purchasing these. Hopefully pick up a few more MPH in the process :D
Did you test the diff between the reg bravo one foot VS the sportmasters you have now?Was there a diff?
Rob :drink:
Strip Poker 388 04-07-2006 08:43 AM
Length
Imco 22"
BMax Ours 19"
Square inches of running surface:
Imco 143 square inches per side
B Max 123 square inches per side
B-Max has 40 square inches LESS running surface total.
Ran-Dom 32 04-07-2006 09:11 AM
Rob :drink:
Std Bravo vs Sportmaster - I gained 4 MPH but I'm convinced it was due to the fact It was a 2 inch shorty - the only real comparison I will have is the BMax vs Sportmaster
Strip Poker 388 04-07-2006 12:30 PM
Keep up posted on what the diff is???
Rob :drink:
RaggedEdge 04-08-2006 05:37 AM
Hey Rad-Dom 32,
The Bravo Shop lowers look good. The water pick ups appear to be similiar to the Merc, your stock lowers are the same low pick up version that are on my '99 35 Fountain. Keep us posted on your progress, Good Luck.
Rebel_Heart 04-08-2006 10:58 AM
I spoke with Dean yesterday at the Bravo Shop. Ran Dom did you send your Bravo lowers to use the existing parts or did you buy the pre-made ones? I think there is a savings of $400/set if you send in your own lowers.
