-   -   alumn. heads and header bolts (https://www.offshoreonly.com/forums/general-q/126911-alumn-heads-header-bolts.html)
tomcei 04-07-2006 08:30 AM
Does anybody use anti-seize or any combound on the header bolts?
axapowell 04-07-2006 10:29 AM
Re: alumn. heads and header bolts
Good Idea to use anti-seize. The two different metals will corrode and bond together.
Dave
Whiteknuckle 04-07-2006 10:37 AM
There was a thread not long ago on antiseize, and it created quite a stir. Personally I like graphite but some of the professionals that should know don't use antiseize on boats.
This should be another good discussion!
deboatmon 04-07-2006 11:32 AM
You might consider studs in the head instead of bolts. I believe there might be some benefits to using studs.
drgnrydr 04-07-2006 11:38 AM
no doubt studs are far superior to bolts & anti seize is a great thing to use I would use c-5a over the others as it uses silver & nickel as a base
pachangalpina 04-07-2006 12:08 PM
I use the ARP stainless studs and Nickle Anti-seize.
tomcei 04-07-2006 06:06 PM
thanks for the info. I know studs are better, but I've never studded the head for headers. I guess I will call around to find header studs. :(
mrhorsepower1 04-07-2006 06:22 PM
Excellent advice.
offshoredrillin 04-07-2006 06:24 PM
Whats everyones opinion on the stage 8 locking bolts? I have them on my Harley and my race truck and love them, guaranteed not to back out.
tomcei 04-07-2006 08:14 PM
just picked up the arp studs from summit :D
Thanks Todd
mopower 04-07-2006 08:42 PM
I used antiseize on anything going into my aluminum heads.
Beak Boater 04-07-2006 08:59 PM
Usually it is just the opposite, because the expansion rate is different, aluminum vs stainless, you will find them in the bilge of your boat. The will loosen and back out on their own. Havent tried the locking bolts but sound like a good investment. That or studs would do the trick.
Griff 04-08-2006 03:41 AM
I would get the ARP SS studs if I were you. I put them on after having to retighten my header bolts several times. Haven't had to retighten them since(60+hrs).
tomcei 04-08-2006 07:50 AM
Got the studs and I'm installing them today, thanks guys
pachangalpina 04-08-2006 12:40 PM
You should have called me, I have a few sets on the shelf. :D
