-   -   HP500 PCV Valve? (https://www.offshoreonly.com/forums/general-q/126971-hp500-pcv-valve.html)
miamioffshore 04-08-2006 01:09 AM
HP500 PCV Valve?
Do 1999 HP500's have a PCV Valve? My manual says it does, but I can't find it! It's not anywhere to be found?
mike11 04-08-2006 01:18 AM
Re: HP500 PCV Valve?
Maybe your intakes were changed. On stock intakes it is located on the bottom right below the carb with a hose coming up to the carb flange.
Mike
Roccard Marine Engines
[email protected]
www.roccardmarineengines.com
570-956-2840
RaggedEdge 04-08-2006 05:22 AM
Stock 500's do have a PCV. Located at rear of carb base, goes from carb flange into manifold just in front of the distributor. The stock intake is a Dart, always painted Merc Hi-Perf blue.
Scott 04-08-2006 10:42 AM
1 Attachment(s)
Follow the arrow
