-   -   Flushing Bravo I (https://www.offshoreonly.com/forums/general-q/127132-flushing-bravo-i.html)
MC-BOYS 04-10-2006 10:37 AM
Flushing Bravo I
Just purchased 1999 Powerquest 260 Lengend with 454 Mag EFI / Bravo I drive. Only 68 hours on boat. Summerized by dealer 2 weeks ago. Here's the question? Started it on the trailer with the Mercruiser low water nose cone attachment. Heavy duty hose 1/2 open with good water flow at start up. Ran the engine 3-4 minutes at no more than 1000 rpms and didn't notice any difference in pressure. Temperature gave up to about 120 degrees. Didn't see much water out the exhaust but after 3 minutes did notice a little water and condensation out my tips and underside of the drive.. sound normal? Also, slight smell of anti-freeze, but just thought it was residual for winterization. Any thoughts would be greatly appreciated.
lennyk 04-10-2006 10:55 AM
Re: Flushing Bravo I
not sure what the nose cone attachment is ...i use muffs to the water pickups..and you should see a ton of water coming out of the exhaust tips
Griff 04-12-2006 12:52 AM
Didn't see any difference in what pressure???????
Most boats wil not get up to full temp on a hose unless they are run for a very long time. After about 20 mins my temp will bounce back and forth between 100-140* when the tsat opens and closes.
You should have quite a bit of water coming out your exhaust. Do you have swichable exhaust???? Is water coming out the drive exhaust/prop???
rich allen 04-12-2006 10:58 AM
If block was empty, it will take a few seconds to fill with water, before it dumps overboard, but 3 minutes? Not that long.
Dave M 04-12-2006 01:10 PM
A 1999 454 should get up to about 165*. It has a 160* thermostat I believe. It's not going to happen in only 3 mins though. My motor will reach normal temp when I run it on the hose.
Like Lenny said, you should see plenty of water coming out the tips.
