-   -   need engine alignment help (https://www.offshoreonly.com/forums/general-q/127539-need-engine-alignment-help.html)
boatnt 04-14-2006 07:07 PM
I just replaced a coupler on a boat.it has regular engine mounts.
I am trying to align the engine.I can get the alignment tool to go in but I have to push a little to get it in.
If I greased the tool and slide it in and pull it straight out I can see at what spot the splines of the coupler hit the tool.
If you are looking at the transom the splines the make contact with the tool are 3 to 6 o'clock.
My question is do I want to raise that side engine mount or do I raise the other side??
how easy should the alignment do go in ?
thanks for any help
GOODT 04-14-2006 07:20 PM
Re: need engine alignment help
adjust the mount oppisite to where you see the marks remember the rear mounts act as a pivot/fulcrum
H2oRigger 04-14-2006 07:21 PM
Hi boatnt. You shouldn't try and do it side to side. What you need to do is lift the engine from the front mount in the middle. I don't know what motor setup you have but it is a bunch easier to Align the gimbal bearing with the crankshaft if you lift from the center front of the motor. or just find two lifting areas on both heads and lift evenly.
Best Regards Phil.
H2oRigger 04-14-2006 07:29 PM
Best Regards Phil.
Oh don't forget after you support the engine,loosen the four nuts that you've been adjusting.
Best Regards Phil
GOODT 04-14-2006 07:30 PM
Best Regards Phil.
no offence but that makes no sense unless Im reading it wrong, if one mount is off how does this help, unless you are starting at square one trial and error, but he already knows which way he has to go
I dont dout you just after doing this for a very very long time dont see it working, im always open to new ideas
H2oRigger 04-14-2006 07:41 PM
I've been doing it that way since 1984. merc even sells lifting tools for alignment. You can do it either way. I just can't see going from side to side when you can just lift the front of the engine,loosen the adjusting nuts and go up or down till the alignment tool go's in easy.
Best Regards Phil
GOODT 04-14-2006 08:17 PM
Best Regards Phil
Then adjust mounts to where you have the engine, I agree have done it that way with new installs and no referance either will work basicly same thing end resolt the same
thanks h20 :drink:
H2oRigger 04-14-2006 08:42 PM
:drink: Cheers :drink:
GOODT 04-14-2006 09:14 PM
h2o tryied to pm you but it says you dont accept them
H2oRigger 04-14-2006 09:16 PM
I check the box to receive mail from others. Don't know why it was unchecked.
Best regards Phil
