-   -   Engines Running Different RPMs (https://www.offshoreonly.com/forums/general-q/127763-engines-running-different-rpms.html)
Chicago290 04-17-2006 04:40 PM
Hi Guys,
I have a PQ 290 Enticer with 454 mags. Since I have had it the tachs have read different RPM at similar throttle openings. The port motor will spin to 5050 RPM but the other will only spin 4800 RPM. What could be going on here? The props are identical and have not been damged. Bad sensor/gauge or is this common and just forget about it? Thanks much.
BajaRunner 04-17-2006 04:45 PM
Re: Engines Running Different RPMs
switch the props and see if it does the same thing.
Joe 04-17-2006 04:58 PM
....or, since they'll be spinning the opposite direction and you'll most likely get a different reading, try switching the gauges. :rolleyes:
BajaRunner 04-17-2006 05:05 PM
true, but to eliminate the props, they will still show the different rpm even spinning the opposite direction.
probably not the best approach to diagnose it though
:cool:
ratman 04-17-2006 05:07 PM
check you carbs and make sure both carbs are opening all the way.
Chicago290 04-17-2006 05:18 PM
Checked the carbs... both are definatley going wide open throttle... even at part throttle the RPMs are different... so i find myslef trying to keep them at the sam r's rather than the same throttle position...not sure which is better
Wally 04-18-2006 09:30 AM
You would need to take the props to a good shop and have them checked to make sure they are identical......i had a set of 23 mirages on my old scarab....had them re-tuned for more pitch....it turns out that all that time before i sent them in, each and evey blade on the props was off!!! They were off by as much as 1 1/2* +/-
See if you can borrow another prop just like yours from a buddy and see if its still not giving you the Rpm's you need...or swap the Tachs and see if it still reads the same...
Boomer 880 04-18-2006 10:39 AM
Is there variation all the way through the RPM range, or just at top end?
Is there any chance that the gear ratios are different in the two drives?
Panther 04-18-2006 10:43 AM
Don't wast time with your props just yet, you need to get a baseline. Get yourself a Snapon Digital timing light so you can hook it up and read your WOT RPMs. Also, let your ear be your guide, you can hear the difference in RPM if they are that much off.
Then check each plug wire to make sure all cylinders are firing, a different of 300 rpms could be one cylinder down.
If all that is good, then start with props, computer and all that other stuff. Check the simple stuff first. :drink:
joe900sc 04-18-2006 11:09 AM
What if any damage to the power train could happen here? Drives?
team Tickfaw 04-20-2006 08:34 AM
Had the same problem with mine last year. Checked rpms at 4 different stages with a digital meter while going down the river. 1500,2500, 3500 and 4500 rpm. Found that in my boat the sync gauge was right. The old faria tachs were off. Got new gaffrig gauges just have not installed yet.
Dave98 04-20-2006 08:57 AM
Wally might be right. It happened to me. Only 25 hrs on the boat. Props looked brand new. Had same problem, not quite the difference though, 4950 vs 4840 rpm or so. Had the props labbed and he reported back that one was a little out of round. We are going to test this weekend and see if the redone props help.
Good Luck.
