Re: HD gimbals,HP gimbals ???
Since posting this thread last year I learned the chad hill stainless gimbal (which I wasted my money on) wouldn't fit without some serious hacking,welding and machining. I also learned a hp gimbal has the side pivot pins that are held in with little screws instead of threading in plus they have mechaincal indicators with cables,this thread is old but maybe this info will help someone with the same question,Smitty
3 Attachment(s)
Here's a few pictures of the HD Gimbal/Transom assembly from Merc. This one is for sale and has 65 fresh water hours on it and came off my boat with twim ram hydraulic steering. It has an XR gibmal bearing in it with 20 hours on it.
This item was listed in the swap section and since it is missing, I will post the asking price here. Just offering info here until the swap section returns. Asking $ 2,350.00. [email protected] Kirk |
i would suggest using the imco gimbal ring and helmut as a pair to insure adding the most strength you ca n to that particular area. the imco requires no mods. i have used it at least several times.
as stated above, launching and rentry is the most stressfull abuse the gimbal with stands . the aftermarket addons i mentioned are the only real im,provements available that i am aware of. and they infact work well. i have rigged more than a few single engine vee-s with 800 to 1000 h.p in them with bravos, and seen almost everything you could imagine in drive and gimbal failure. the imco parts work. good luck |
| All times are GMT -5. The time now is 12:22 PM. |
