Stripped upper drain plug on Alpha Gen II
A buddy of mine just had his drives serviced and they said he has a bad upper drain plug on one of the drives. It won't tighten down...threads are stripped.
Any suggestions besides replacing the whole upper housing? Ever re-tap and/or use helicoil? What should he watch out for? Thanks All! |
Re: Stripped upper drain plug on Alpha Gen II
Surely this has happened to somebody?
I know...don't call you surely. |
There is not enough material in the case to hold a helicoil. You ight be able to drill out and tap for a larger plug or have someone weld the hole shut and redrill and tap.
they make threaded inserts that work. the outside can be the next size up or the one after that as well. i found them at msc industial supply before. they may help. got nothing to loose.
| All times are GMT -5. The time now is 05:03 PM. |
