-   -   Shorties or Std. Bravo length drive? (https://www.offshoreonly.com/forums/general-q/128306-shorties-std-bravo-length-drive.html)
Rebel_Heart 04-23-2006 10:16 PM
Ok, it's down to the wire. I have to decide whether to run 2" shorties for the year, or wait until next. I have my new engines almost ready and have to sh*t or get off th pot.
Would you run my existing Bravos as is for the first year or try the 2" shorties right away? If I don't do the 2" shorties, I'll still have to buy new props with the 1' prop shaft, then next year buy those that fit the 1 1/4" shafts. Looking for suggestions as Jim V. is finishing my heads over the next 2 weeks. Engines will be around 700 hp NA. I don't want to waste money at this point, but if 2" or 1" lowers would make a difference I would be there.
2001 35' single step Classic Fountain
Thanks for any suggestions!
Ran-Dom 32 04-24-2006 08:11 AM
Re: Shorties or Std. Bravo length drive?
IMO go for it, there no doubt your going to see a gain with your particular set up.
racinfever 04-24-2006 10:53 AM
I would save my MONEY your drive height is high now for big motors . You can change hubs in your props if you do shorties later !
Rebel_Heart 04-24-2006 11:07 AM
Two different responses. Care to share your experiences with shorties and the gains? Thanks for the tip on changing out hubs if I don't change lowers. Although, it may take a different prop when raising the drives do to slippage.
PatriYacht 04-24-2006 01:29 PM
There's no way to know if the shorties are an improvement if you change them now without trying out the new engines first. Shorties are not cheap. Find out how fast your boat is and then try the shorties.
Viper31 04-24-2006 02:27 PM
Get your Xdim and call Fountain to see if what you have is optimum.
Rebel_Heart 04-24-2006 03:16 PM
I found the best prices from the Bravo shop.
Fountain said my x dimension was 16 3/4, while the new Executioneers are 2" higher with 1.65 gears, while mine are 1.50. I just don't want to pay $6,000+ without the potential for additional speed. I know that there would be extra slippage with the higher x.
Anyone with a similiar boat have expeience with the shorties, either positive or negative? Thanks.
Zanie 04-24-2006 03:29 PM
Talk to Marty Sanborn, he's very helpful!
Z
Panther 04-24-2006 03:30 PM
Do your changes in incraments, you'll never know what you gained or lost.
Put the motors together, test and dial in. Then mess around with drive height etc. You'll be running around in circles testing things and may go back to what you had to begin with. :rolleyes:
