Old style CMI
1 Attachment(s)
I have the old style elbow tops with the standard bravo wet tailpipes, but I wanna convert to dry tails. I have not cut the transom holes yet thats why I'am looking for a good pair of dry tailpipes for bravo now. Is the new style compatible with the old rope sel type? , If not do any of you guys have a a pair of old style dry for standard bravo holes. I also need 2 stearing rams [imco, mayfair, latham] with the bravo cap, Plz pm meif you have any of this. Thanks
Re: Old style CMI
so...
Re: Old style CMI
Do you already have holes drilled in the trasom?
Re: Old style CMI
no
Re: Old style CMI
I have a new set I can make you a great deal on.
If interested, I can be reached toll free: 866 921 4553 Fred @ Trick Marine |
Re: Old style CMI
I had this done on my boat last year. The welder cut the ends of the old pipes off, then extended the pipes out the existing holes. There is a small hole at the end and bottom of the pipes so a small amount of water cools my mufflers, the remainder of the water comes out 1/2" bungs welded onto the pipes on the inside of the boat and dump overboard. |
| All times are GMT -5. The time now is 12:13 AM. |
