-   -   Prime a new trim pumpp (https://www.offshoreonly.com/forums/general-q/129016-prime-new-trim-pumpp.html)
boatman747 05-02-2006 08:38 AM
Im installing a new trim pump . How do you prime it ?
Iggy 05-03-2006 05:15 AM
Re: Prime a new trim pumpp
I don't believe you have to. I think the pump is a positive displacement type, meaning it is self priming.
I blew a line a couple years ago, drained the system into a lake. :( I replaced the hose, flushed it, filled it, and just ran it up and down to bleed the air out.
happy hours 05-03-2006 07:45 PM
Ditto, I rebuilt a pump and fill the reservoir and trim up and down...will make all kinds of ugly sounds and it purges air...keep and eye on the fluid and keep cycling the pump..will self purge.
GOODT 05-03-2006 10:38 PM
they are 100% correct hold up all the way then down it is self bleeding
ActiveFun 05-03-2006 10:41 PM
Drained the system into a lake :eek: :eek: :eek:
Iggy 05-04-2006 05:07 AM
Yes.....I didn't find it out till I tried to raise the drive for trailering. :mad:
Not only did I empty the system, but filled it with water trying to work the trim. Had lots 'o fun flushing everything. :(
