-   -   dry sump #6 question (https://www.offshoreonly.com/forums/general-q/129090-dry-sump-6-question.html)
glassdave 05-02-2006 09:06 PM
how do you tell if a number 6 is a dry sump drive or wet. a friend purchased a boat with 6's and was told they were dry sumps. is there a reservoir? some kind of pump or lines? i really didn't see anything on the transom assembly but than again i am not terribly familiar with the setup. just curious at this point
KNOT-RIGHT 05-02-2006 09:24 PM
Re: dry sump #6 question
Look under the cavitation plate on the inner side if they are spinning in. There is a screw to check the level.
If you drop the lower from the upper there will be a spray bar
between the two gears.
Taking for granted they are the early style.
Here
http://www.mercruiserparts.com/Show_...+Driveshaft%29
Here
Compliments of BAM
Thanks Marc
Gerry
glassdave 05-03-2006 12:14 AM
i believe they are about a 2000's or so, new style skeg. all the dry sump hardware is internal than? Thanks
glassdave 05-03-2006 08:52 PM
? ? ? t t t :D
Pwrbt33 05-04-2006 05:54 AM
Yes, everything is internal. If you look at the right side of the anti-ventilation plate about 2" back from the front there should be a vent plug. This will be your full level. If there is not one on the right side fwd, most likely its a wet sump.
John S. :D
