-   -   Gen 4 cooling (https://www.offshoreonly.com/forums/general-q/129352-gen-4-cooling.html)
nordic95 05-05-2006 09:34 PM
Gen 4 cooling
Finally got my winter project into the water today :D :D .Boat ran great,but I still have a couple little tuning issues to deal with.Here is my question:
Boat has a gen 4 and a gen 5 502 engine,Don't ask!!The gen 5 ran good all day and temp stayed at 135 till ran hard and went up to 150.Two to three pounds water pressure in both engines at idle and around 27 psi a 5000 rpms.The gen 4 ran great but water temp went up 180 and then down to 130 again and again.I changed thermostat and it didn't make a difference.What the heck would cause this?? :mad: Motors are brand new and I know first hand there are no restrictions in cooling system.Could it be a steam pocket??Both motors have stock circulating water pumps.
Please help,I know someone here has had to have had this problem before.
Nordic95
GOODT 05-06-2006 07:10 AM
Re: Gen 4 cooling
The gen 4 is cycling, it could be the way it is plumbed or you might just have to put a by pass hole in the stat
RLW 05-06-2006 07:16 AM
Re: Gen 4 cooling
What's a Gen 4? Is it the same as a Mark IV?
nordic95 05-06-2006 07:26 AM
Re: Gen 4 cooling
yes
nordic95 05-06-2006 07:30 AM
Re: Gen 4 cooling
The plumbing is all stock basically,except I just ran the hoses a little differently but to the same locations.I read a lot of post on here last night and it seems steam pockets are a big issue with the Gen 4.I am going to try and drill the thermostat today and see what happens.I think it is because right next to the thermostat housinf the manifold gets real hot,can hardly put a hand on it,then it cools quickly.The rest of the motor stays nice and cool at all times.
Thanks Goodt
GOODT 05-06-2006 07:35 AM
Re: Gen 4 cooling
from what you discribe I think drilling the stat should fix your problem
RLW 05-06-2006 07:48 AM
Re: Gen 4 cooling
Is there a Mark V and Mark VI?
nordic95 05-06-2006 06:32 PM
Re: Gen 4 cooling
I drilled the stat today and it didn't make a difference.I started out with two 1/8 holes and then drilled two 1/4 holes,temp still rises and then falls back to 130 degrees.Now what should I try,any solutions????
Thanks Nordic95
jryan26 05-06-2006 06:47 PM
Re: Gen 4 cooling
I have a mk5 and a mk6 in my boat!
Nordic95
nordic95 05-06-2006 07:31 PM
Re: Gen 4 cooling
Hey guys,
I just noticed looking at pictures of my old motors that I did remove the 1/2 bypass hose that goes from the top of the water pump to the old thermostat housing.My new housing does not have a provision for it.Can this be my problem?I think this would put water pressure from under the thermostat,is that right?That would act like a large hole in the thermostat to keep pressure even on both sides of it,I think.
Nordic95
GOODT 05-06-2006 07:34 PM
Re: Gen 4 cooling
yes, more then likely it is
nordic95 05-06-2006 07:38 PM
Re: Gen 4 cooling
I heard of people running a bypass hose from the front to back of manifold,will this help?Or should I drill and tap for the stock bypass from pump to manifold?
Nordic95
formula31 05-06-2006 07:43 PM
Re: Gen 4 cooling
Hey guys,
Nordic95
You mean to the intake right? Ive never tried to run without one. Your intake doesnt have a bypass port in it?
nordic95 05-06-2006 07:54 PM
Re: Gen 4 cooling
Yes,to the manifold.Now I'm running Hardin Marine manifold and no provision for the by pass hose.I was told I didn't need it.My Gen 5 doesn't have it either and it runs fine.
Nordic95
GOODT 05-06-2006 08:01 PM
Re: Gen 4 cooling
2 Attachment(s)
can you email me pics of your setup????? just doesnt sound right, this is basicly how it should be set up
nordic95 05-06-2006 08:51 PM
Re: Gen 4 cooling
1 Attachment(s)
Goodt,
Here is a pic of the engines.
GOODT 05-06-2006 09:17 PM
Re: Gen 4 cooling
I think the problem is the bypass but if you give me a call tomorrow Ill give you some other ideas to try, are you running a dry joint between the manifold and riser???? ( solid gasket, no holes )
nordic95 05-06-2006 09:24 PM
Re: Gen 4 cooling
Yes,and the manifolds are also brand new Revolution Marines.I also just noticed in my picture that the manifold has a tap for the bypass hose,but that manifold is on the gen 5,the gen 4 is on the right.No provision for the bypass on the manifold for the gen 4.I wonder if the manifolds are mixed up?
tggrounds 05-06-2006 09:28 PM
Re: Gen 4 cooling
Those engines look sweat. Could one of your temp gages be off ?
nordic95 05-06-2006 09:30 PM
Re: Gen 4 cooling
Thanks,I checked guage and sender.I think its a steam pocket or a hot pocket,just can't eat it!!!
joee 05-07-2006 04:35 PM
Re: Gen 4 cooling
Hey guys,
Nordic95
I had the same problems when I put a supercharger on my Merc 425 HP Gen IV engine. The B&M manifold had also no provision.
Therefore I first plug the venting hose located on the top of the circulation pump and the cooling water temperature rose up to 100 degree Celsius (212 F).
After installing a pipe with a restrictor which I drained into the bilge the cooling water temperature became normal.
Joee
