Turbolator Plate
I am making some changes to my exhaust. Do I take the turbolator plate out? The motors are Mag HOs. I do not idle long times and boat in inland lakes. My warranty has expired.
I know this has been discussed before but last night when I had the exhaust all apart I was thinking.........that Merc Engineer is smarter than me...... Thanks in advance |
Re: Turbolator Plate
Thanks in advance |
The main purpose, I understand is to catch condensation from inside the pipes. Not so much a factor in stopping reversion at idle.
I wonder if it would help to drain the water out of your pipes if you are going to leave it sit for a few days. All it would take is a drain valve in the hose going from the manifold to the riser. |
Interesting Subject I Too Have Gill Manifolds, But My Pipes Dont Mix Water Till The Very End...those Plates From Mercury With The Gaskets Were A Whooping 230 Bucks Dont Tell Me I Robbed Hoarsepower And Wasted Money...............
The condensation forms inside the risers as a result of the temperature difference. It happens in all jacketed risers. Reversion has nothing to do with it. Draining the water jacket would have little ot no effect. The standard gil plate is large enough for most engines. I understand the 496 is another matter altogether and may be too small. I am keeping mine to keep my valves seats in good shape and hopefully prevent any rusting caused by a drop of water running down from the top of the riser.
I'm yanking them, what the heck. If it only makes it louder all the better. One inch extra diameter per pipe in trade for a drop or two of water. There are more common things done to boat motors daily with far more consequences than a drip plate removal.
We removed the "turbolators" on our 496 HOīs last season (Baja 272 and 25 Outlaw). No, it didnīt even bring 50 revs or a 1/2 mile! Absolutely nothing. If you look at a section through the pipes you will see that the inner diameter of the elbows is only fractionally larger than the hole in the plate. Donīt bother!
RECKLESS, you better get on it, your still in the driveway! It was 82 degrees today.
Louder? Lets see, a new stereo sub & amp to hear tunes on plane, so lets make the engines louder.... - Just yanking your chain bro.. :) See ya soon. And don't forget, I am off all next week, my ride, if you have some free time. Bryan |
1 Attachment(s)
all the better i am just pissed i spent all that money on them,,,,,thanks guys i will leave them in my boat is to loud as it is............
1 Attachment(s)
Wow, youīre absolutely right. There is quite a difference in diameter! I missed that!
It didnīt make a difference to the performance, though. However, if a 496 is already running at a max around 5000 revs, maybe it needs more than a little extra gas flow to free up more horses at the top end. 496īs tend to produce their best speed figures a tad below 5000 revs. |
| All times are GMT -5. The time now is 05:04 PM. |
