-   -   Indestructible Sea Pump Impellar? (https://www.offshoreonly.com/forums/general-q/129959-indestructible-sea-pump-impellar.html)
White Knuckles 05-12-2006 11:10 AM
Any of you guys running this dry-run technology impellar kit from Trick Marine? Have you run it dry? This would sure save alot of PITA if it is real.
http://www.trickmarine.net/productde...?productid=907
ratman 05-12-2006 06:35 PM
Re: Indestructible Sea Pump Impellar?
i just installed them on both my motors, i going out this weekend i'll let you know how they work.
Too Old 05-12-2006 06:57 PM
There's a lot of guys running them and I'm sure they'll speak up.
The Fountain of Youth/Konrad race boat has some time on theirs I'm sure.
We ran the kit on a parasail boat out of Myrtle Beach that has 1400 hours without an impeller change.
MOP 05-12-2006 07:45 PM
That impeller has been around for many years it was first distributed by Barco which has since been bought Globe. You can get them to fit just about any pump made, the perfect combo is the Merc bronze pump and that impeller. The trick pump does not appear to have a S/S liner if so aluminum goes to hell to quick.
Phil
offthefront 05-13-2006 06:28 AM
what do you get for the 189.00 ?? just the impellar,O-rings and wear plate ?
Too Old 05-13-2006 07:44 AM
You get the back half of the pump......incudes impeller, housing, and fittings.
The impeller is not a Globe as implied by Phil.
One year warranty on impeller five year warranty on the remainder.
I've sold a ton of these. Zero impeller replacements. One customer with 1400 plus hours in salt water use.
BillR 05-13-2006 08:10 AM
Will this fit the Merc seawater pump that has the fuel pump attached?
http://www.mercruiserparts.com/Show_...+PUMP+ASSEMBLY
Big Block Billy 05-14-2006 12:10 PM
What do you guy's think of running a Globe blue Impellor in a Jabsco Bronze pump ? That pump body from trick resembles a Keith Eikert model. It probably is less prone to hi-rpm cavitation.
A while back I was told that the Globe impellors "lay over" at high RPM. Is this known to be true ? BBB
