Re: Swapping my 454 with a 502 in a 22 Scarab
Does anyone know if a new flywheel is already at neutral?
For what its worth this is the follow info on the flywheel I was talking about. Notice in Bold where is stats a neutral flywheel.
Brand: GM Performance Parts Product Line: GM Performance Parts Flywheels Ring Gear Tooth Quantity: 168-tooth Rear Main Seal Style: 1-piece Flywheel Material: Cast iron Maximum Disc Diameter (in): 11.000 in. Engine Balance: External Balance Style: Neutral Replaceable Friction Surface: No Safety Rating: SFI 1.1 Quantity: Sold individually. Flywheel, 168-Tooth, 11.00 in. Diameter, Cast Iron, External Balance, Chevy, 7.4L/454, Each Check to make sure this part fits your application The right flywheels for big or small blocks. It's not important whether you have a big block or a small block, you can be sure that GM Performance Parts have you covered. They have high-quality lightweight nodular iron and billet steel flywheels to fit your needs, no matter what flavor of V8 interests you. |
| All times are GMT -5. The time now is 05:12 AM. |
