What are the symptoms of a spun bearing?
I found some silver snot in my first oil change and it wasn't iron/steel material. This was on a fresh 350 with 2-3 hours on the first oil change.
Ken |
Re: What are the symptoms of a spun bearing?
what do you mean by fresh, new, rebuilt ?????
You should not see anything noticeable |
remanufactured GM marine long block. Would the silver snot be consistent with bearing material?
could be rod and main bearings are made from several materials including zinc, brass, bronze, ect
u may have wiped a cam lobe, does it run smoothly? do you hear any knocking?
When you say re manufactured GM engine, are you saying the engine was rebuilt by GM? Or was this a straight out new marine engine. When I say straight out new I mean the block has never been rebuilt.
some of the "cam lube" has moly in it and can make the oil look like metal flake
Re: What are the symptoms of a spun bearing? A drop in oil pressure, especially when thoroughly warmed up and at idle speeds after a hard run. --- Jer
if you spun a bearing youd know it trust me KNOCK KNOCK KNOCK KNOCK
AND YES DROP IN OIL PRESS |
"if you spun a bearing youd know it trust me KNOCK KNOCK KNOCK KNOCK" as Goodt states. Yes, IF it is a rod bearing. But if it is a main bearing, you can still have "the silver/bronze death" and not hear a thing. --- Jer |
| All times are GMT -5. The time now is 12:13 PM. |
