-   -   Setting Timing on 500EFI (https://www.offshoreonly.com/forums/general-q/130630-setting-timing-500efi.html)
Dock Holiday 05-21-2006 09:31 AM
Please confirm that the following steps are correct for setting the timing on a 500EFI.
Hook up timing light to #1 cylinder.
Hook up scan tool and put engine into service mode.
(or put a paper clip as a jumper between "A" & "B")
Run RPM's up to 1500 to 1800 RPM then check to see if base timing is at 8 degrees.
If anyone can confirm that these steps are correct I would appreciate it.
Dock
Dave_N 05-21-2006 11:34 AM
Re: Setting Timing on 500EFI
1 Attachment(s)
Pretty close...
Dock Holiday 05-21-2006 01:23 PM
It doesn't get any better then that!
Thanks Dave
