Drive goes 'In' not 'Out'..won't lift
I have an 84 26 ft Chris Craft Stinger with twin 350's and alpha drives. After being out on the water all day yesterday I noticed that my Starboard drive hadn't lifted when I pulled it out of the water and onto the trailer.
I can hear the pump work when I move the lift switch to 'In' (lower the drive) but only silence when I move the switch to 'Out' (lift the drive). I can run it like this but am concerned about dragging the outdrive when trailering. Could make a real neat groove in the road though(not). Any thoughts? Thanks |
Re: Drive goes 'In' not 'Out'..won't lift
The up solenoid or the switch, check it out with a volt meter to see if both the blue & white wire at the pump is getting power. If it shows good current then get a new solenoid, it is a pretty easy and quick job.
Phil |
have you tryed it with the trailer switch if it works with the trailer switch it means that you need a trim limit switch
| All times are GMT -5. The time now is 06:29 PM. |
