-   -   oil filter pad adapter (https://www.offshoreonly.com/forums/general-q/130726-oil-filter-pad-adapter.html)
klaw 05-22-2006 12:09 PM
I am thinking about upgrading my 500 hps with larger oil lines and would replace the adapter omn the block that sits where the oil filter ussually does and cppreformance has a nice looking on with the oil line exiting the side versus the bottom this would alos clean up the plumbing a bit
Anyone have a suggestion on these or anothe rmfg.
Vinny P 05-22-2006 05:29 PM
Re: oil filter pad adapter
1 Attachment(s)
I just installed a system from Hardin Marine. I used 3/4" pipe fittings and -12 AN lines. So far, its works great.
GOODT 05-22-2006 06:33 PM
teage or hardin
RLW 05-22-2006 07:18 PM
1 Attachment(s)
http://www.stefs.com/products/adapters.htm
This is the Stef's adapter I am using on my Dart Big M block.
A quality piece.
TC 05-22-2006 07:42 PM
I just just completed the install of a complete Hardin Marine oil system upgrade. I used a thermostatically controlled combo cooler, new filter head and block adapter from them. All parts appear to be of superior quality! The block adapter is actually a piece from Keith Eickert. I will be priming and running the engine tomorrow for the first time this season. Can post pics but my install looks alot like checkmate454mags. Good luck!
Elite Marine 05-22-2006 07:57 PM
Anyone have the HP500 set up for sale???? I'd like to buy one soon!!
articfriends 05-23-2006 03:25 AM
1 Attachment(s)
Anythings better than stock merc,just don't buy anything thats cast aluminum vs billet as it will crack and you should use -12 hose and fittings so that your tightest/smallest restriction is at least 1/2 inch,Smitty
