-   -   Elictrical short (https://www.offshoreonly.com/forums/general-q/130981-elictrical-short.html)
muffin 05-24-2006 11:40 PM
Elictrical short
I have a short somewhere! I have twin batteries...both with cut offs. The dials are 1,2,both or off. When both batteries are in the "off" position, I can still run the motor for the motor cover. However, when the motor cover is open, I still get a spark when I hook up my second battery. Why would I have a draw with nothing running? Where should I begin to look? Thanks to everyone who may be able to help.
Tom
GOODT 05-25-2006 03:55 AM
Re: Elictrical short
more then likley you have someting hooked up that bypasses the switch...When I install battery selector switches I ussually install the bildge pump wirring bypassing the switches so that the pumps will come on even with the swiches off
What you need to do is remove the switches and see what they have hooked up to the "common" post also whats hooked up directly to the batterys
Audiofn 05-25-2006 07:16 AM
The easy way to look for draw is to use a test light. Pull off your ground cable and put the test light btwn the ground terminal on the battery and the cable. If you have a draw the light will come on. As has been mentioned this could be a computerized bilge pump that is coming on automatically when you put the battery on, or even water in the bilge causing it to come on. It will run for a few then shut off. You do not likely have a short. If you did you would probably smell wire melting. You probably have a draw. Once you have the test light hooked up you can pull fuses and such tell you see the light go out and then you will know what you have as the problem.
Jon
Airpacker 05-25-2006 08:08 AM
I would look at stereo amps being hooked up bypassing the switch. Capacitors in the amps will draw current until they are charged, then stop. It seems like many stereo installers like going directly to battery supply for amps because taking the battery switches off and connecting there is too much work.
muffin 05-26-2006 10:26 AM
Thanks for all the input...going to run this weekend...will keep you posted!
Wobble 05-26-2006 10:34 AM
Great advice above, the only other draw that is often overlooked is the radio's memory circuit, often goes to the battery to keep the radio stations programed
BajaExpress 05-26-2006 08:13 PM
Ck the hour meters to see if they are wired correctly and if you have a dash clock.
