-   -   Blower recommendation for 700 hp (https://www.offshoreonly.com/forums/general-q/131035-blower-recommendation-700-hp.html)
klaw 05-25-2006 01:57 PM
well been toying with the Idea of uping my 500 hps they right now have been dynoed at 565 hp was wondering what you guys would recommend for a blower carb package to get me to 700. I know I need other bottom end and piston cam work but just want to research the blower carb first
jryan26 05-25-2006 03:01 PM
Re: Blower recommendation for 700 hp
klaw
what got them to 565? Did you up the compression? From what I understand, they have forged pistons anyway. Im putting prochargers on my 500s and hoping for at least 700. I would think that by putting M3s on them you would be there easily. PM Cigdaze. He has a nice low hour set for sale.
ActiveFun 05-25-2006 03:11 PM
BDS 875, 2 750 cfm's?? Hows that for a start?
jdnca1 05-26-2006 07:48 AM
8-71's and 825 Demon blower carbs....Probably make 700 at 3-4# of boost. Cheap and easy to tune. I would leave the bottom end alone and you really don't need a cam change if you're only looking for an honest 700HP.
Von Bongo 05-26-2006 09:28 AM
Chief got 700 out of mine with Blower Shop 250's.
When we completely rebuilt them they made 680 at 5500 and we were conservative with the set up. A bigger blower spins slower and less heat but I wanted to keep everything as low profile as I could.
birdog 05-26-2006 03:38 PM
My choice !....I made 650 hp with 8-71s..750 Hollys & 4 lbs boost. Mild cams {468ci}...You will have a little more Comp. Better carbs, more cubes.
tomcat 05-26-2006 10:29 PM
2 Attachment(s)
Why only 700 HP? That's a great engine to supercharge; with more boost and an intercooler 800 HP is easy . Lowering compression and a bigger cam are not necessary. Nickerson single blowthrough carb needs practically no tuning, just pay attention to the fuel supply system and ignition system.
