Flush Valve
Who makes a good "flush valve". I want to tee into the water supply line so I can run the engine on the hose without putting the muffs on the drive. I have seen them with a check so that the water does not go back out the drive, but don't know where to find them. Thanks
Re: Flush Valve
1 Attachment(s)
You need a large gate valve on the seawater side of your sea-strainer and a ball valve on the flush inlet. put the flush inlet on the other side of the sea-strainer.
You can get these valves from Grainger, McMaster Carr or any good industrial supply. |
Re: Flush Valve
This company advertises in the local boat magazine called the NorEaster
http://www.marinetechgroup.com/ http://www.marinetechgroup.com/images/750IO_small.jpg A little pricy...but looks like a ready to go solution. |
Re: Flush Valve
perko makes one that goes in the inlet hose. retail 92.00 with two clamps.i put five in this year. simple.
Re: Flush Valve
I have the Perkos, they work fine, no valves to turn (or forget to turn :eek: )
Re: Flush Valve
I have installed many of the Perko Proflush kits all with great results
Re: Flush Valve
Thanks for the response. Sounds like Perco is the way to go.
| All times are GMT -5. The time now is 01:03 PM. |
