-   -   trim switch replacement (https://www.offshoreonly.com/forums/general-q/131362-trim-switch-replacement.html)
jjj 05-30-2006 09:05 AM
I have a merc 3000 classic throttle/shifter that needs to have the rocker trim switch replaced (no up). Any advice/instructions on how to do this and a pt. no. would be a great help. Thanks in advance.
GOODT 05-30-2006 06:12 PM
Re: trim switch replacement
how do you know its in the shifter switch and not in the trim limit switch ????
jjj 05-31-2006 06:29 AM
Continuity at the trim limit switch connector. (I should have noted that earlier.)
Iggy 05-31-2006 07:04 AM
Look here for your control assembly. Part numbers are at bottom of page
http://www.mercruiserparts.com/selec...EMOTE+CONTROLS
jjj 05-31-2006 07:48 AM
Thanks Iggy, I see the parts needed.
To get at them, is it only necessary to pull ? out the neutral button (It. 6) and remove the locking bolt (It. 7)
Iggy 05-31-2006 11:22 AM
After looking at the parts breakdown, I'd say yes. The neutral button has to be pulled. Then you can remove the bolt holding the lever on and pull the lever. Once removed the cover screw can be removed.
Witout seeing it first hand I don't know if the cover screw can be accessed without removing the entire lever.
jjj 05-31-2006 11:28 AM
Thanks, I will try it this weekend, weather permitting.
jjj 06-05-2006 09:08 AM
Tried to pop off the neutral button to get at the screw yesterday but it wouldn't come out, I was afraid of breaking it. Anybody know more about dissassembling this remote control (Merc 3000 classic) ? Thanks
