waterin bilge
fountain 35ex water in bilge.i checked all the hoses when running no water but water in bilge checked the bellows dry.could the water comr=e thru the bilge pump fittings they are very close to the water line?
Re: waterin bilge
Could be backing up through the air vents beside the swim platform.
Re: waterin bilge
My circulating water pump was bad last year. At idle, no symptoms, at WOT, water would come out of the weep hole on the bottom, like when a car water pump goes out. Only found the problem when i was checking the timing on the motor. No overheating or other symptoms.
That could be your culprit. |
Re: waterin bilge
I just had to change the seal on the top of the gimbal ring where the pin connects the ring to the housing...I hear it's very common.
Re: waterin bilge
nope to all above still waterin the boat is new and has 2 hours on it.
Re: waterin bilge
Take some strawberry jello and dust the bilge area when its dry down there.....go for a ride and see if it will show you where the general area the leak is coming from. Theres soo many places water can come from....
Ive seen the raw water pumps with hairline cracks in them that dont show up till the boats on plane then the combination of the engine RPM and water PSI from the outside lets water seep in.....or on my old scarab the bottom water pickup wasnt sealed properly and it leaked into the hull.....but not past the fitting on the inside of the boat!!...NO It found its way THROUGH the hull and was leaking by a support stringer that had a small crack in the corner!!! Drove me crazy :( |
Re: waterin bilge
Wally, thats a great Idea never tought about it.......
like dad use to say " Any day you dont learn something is a day wasted " Thanks |
