Drive spacer install question
There are O rings between the upper and lower housing. The spacer does not have any O rings between it and the upper housing, only the bottom.
Is this right? I have an XR drive. |
Re: Drive spacer install question
I justr did this ....IMCO spacer on an IMCO shorty. The grooves in the spacer go up to mate with o-rings to the upper housing . the bottom of the spacer has no machining grooves and mates with the o-rings in the lower unit portion of the drive. Does any of this make sense?
Make the spacer mate up just like the lower would mate up with the upper. Bryan |
Yes, it makes sense. I put it on upside down. I did not think the non-gooved would facing down would flatten the O ring for a tight seal. But thinking about it the grooves on the lower are big enough for expansion.
Thanks |
Just realized, the spacer can only go on 1 way.
Hey PE,
How far are you spacing it down? When do you plan to be out on the island again? later, |
Hey Pat
My drive was set up 1.5" higher than from Superboat. So I put a 1.5" spacer on. I just can't seem to get the boat "loose" at speed. feels like I'm towing a skiier! I trim it way up, then it is too loose, or I lose bite. Don't know if you noticed but I am throwing a small rooster tail. I don't think I am getting enough leverage to lift the boat. In rough water, when the boat comes out and the drive stays in the water the boat really lurches forward. Do you think I'm heading in the right direction?? |
If you look at my avitar, you can see how much boat is in the water.
Originally Posted by Pure Energy
Hey Pat
Do you think I'm heading in the right direction?? I believe that the "standard x dim" has the prop shaft 3-1/2 to 4" below the bottom on the Y2K. Jcap had his best results with a 2" spacer and Krack has had good results running with a 1" spacer. My boat is quite different being that it is only a 24' and does not have the notch, but the prop shaft is 5" below. I believe the newer 24s with the step and semi-pad are set even deeper; Dave M. measured his at like 6-1/2" below. The slip numbers Dave and I see are a lot better than the 30s. Is it because the prop is deeper??? I'm sure that is part of it... Good Luck, be safe and have fun with your testing! :D |
| All times are GMT -5. The time now is 07:29 PM. |
