-   -   oil cooler plumbing (https://www.offshoreonly.com/forums/general-q/131681-oil-cooler-plumbing.html)
nordic95 06-01-2006 06:38 PM
oil cooler plumbing
Is it better to plumb cooler so hot oil goes into cold side of cooler or sea water exit side and why.
Nordic95
TC 06-01-2006 06:48 PM
Re: oil cooler plumbing
I ran mine so that the hot oil would be flowing in the opposite direction of the water flow through the cooler. Does it really matter??? I would say it could make a difference if your cooler was barely capable of cooling the oil due to performance upgrades. If you have a large efficient cooler it probably would not matter. Just my .02
nordic95 06-01-2006 08:16 PM
I was thinking of plumbing the same way you did.I figure it is better to let oil cool as it travels towards cold water side.
Nordic95
RLW 06-02-2006 02:30 AM
Yes, common practice is to flow oil opposite of water flow. This is refered to as counter flow configuration versus parallel flow configuration.
