-   -   thunder bolt 4 coil (https://www.offshoreonly.com/forums/general-q/131803-thunder-bolt-4-coil.html)
tomcei 06-03-2006 02:40 PM
thunder bolt 4 coil
Is there anything special about the TB4 coil ? Can I replace/ substitute with msd coil and keep my Distributor and module?
shawn 06-03-2006 04:16 PM
Re: thunder bolt 4 coil
I replaced mine with MSD and kept the old one on the boat as a spare, just in case.
GOODT 06-03-2006 05:46 PM
yes you can replace simple swap out
tomcei 06-03-2006 06:18 PM
cool,... I didnt know if mercury had some special incompatable set up.
Thanks,
Tom
dave911 06-03-2006 07:33 PM
Any benefits to the MSD over the TB4? I just bought a boat with slghtly built small blocks and TB4s...Thanks
GOODT 06-03-2006 09:03 PM
the msd has stronger current which translates to better burn
(the simple answer)
MOP 06-03-2006 10:08 PM
On my 383 I swapped the Tbolt coil that I was told was a 40,000 volt coil for a Jacobs 60,000 volt coil. It looks nice but did little to nothing for performance, 90% of the engines just do not need the extra zap. Tbolt is pretty decent setup don't let anyone BS you.
Phil
Olds Eddie 06-05-2006 07:03 AM
If you use an MSD coil make sure it is the 'high vibration coil' or it will not last long. The only time a coil change will help performance is if the old one was weak.
vandeano 06-05-2006 07:40 AM
Like my Uncle Melvin use to say "You don't need a forest fire to light a cigarette, when a match will do".
tomcei 06-05-2006 10:27 AM
thanks guys, the one I have has physical damage. It works well but I'm not sure if it's working as well as it could.
