speedo no worky?
Where do I start. 1995 32 Caliber,502's,bravo's. The needle doesnt even move. Anyone?
Re: speedo no worky?
Make sure the pick up hole is not plugged and also the tube didn't come off the yellow fitting (very common) I zip tie the tubes on the yellow fitting to prevent them from coming off again.
maybe no suckey suckey.....
if you dont have an external pick up.... there is a small hole on the leadinding edge of the lower part of your drive it is very common that this gets clogged, sometimes it can be cleaned out with a piece of wire and a little air |
YOU BREAKEE u BUYEE, no touchee. 4 doola i fixee. :D
If you use air use the tube with about 10PSI do not blow into the hole you will just jam the crap tighter. Apply the air pressure then take a thin but stiff piece of wire and work it into the hole once air starts to flow disconnect the air fill the tube with water then blow that through a few time to wash the debris out. To get it good and clean do a run with the tube disconnected so water can flow freely through it, using that method I have cleared dozens for my customers.
Phil |
Phil That sounds familar........... :rolleyes: :rolleyes: :rolleyes: |
thats funny... |
Phil ditto,,,,, my previous comment was in good fun, i was just in a dollar store. no harm ment. |
Looks like there is possibly a stuffed up hole on my starboard outdrive, I tried twisting a small drill bit in to it by hand but it was not going in. Is there only a hole in the starboard outdrive? I did not see one on the other outdrive?
should be in both |
| All times are GMT -5. The time now is 07:15 PM. |
